Engine
Pistons: 87 mm, 13:1 Extreme Tuners Custom Pistons
Connecting Rods: Extreme Tuners Custom Connecting Rods
Connecing rod bearings: UPG Specification
Main Bearings: UPG Specification
Cylinder Head: CNC Heads UK
Head gasket: Athena MLS 1.9mm
Camshafts: Extreme Tuners Custom
Valves: 1 mm oversize
Valve springs: Custom double springs
Retainers: Custom Titanium
Lifters: Custom Mechanical
Camshaft pulleys: Cat Cams
Throttle bodies: 48 мм Jenvey WTCC
Exhaust manifold: 4-2-1 BTB
Bolts: ARP
Clutch: Custom 4.25” Twin Plate
ECU: Haltech PS2000 + Racepack Dash IQ3
Fuel system: Nuke Performance
Fuel Injectors: Bosch 440cc
Oil system: Titan Motorsport Dry Sump
Brakes and transmission
Brake System: UPG
Handbrake: D2
Gearbox: Custom
Differential: Quaife ATB Helical LSD
Suspension
Front shock absorbers and springs: KW Coilover
Rear shock absorbers and springs: GAZ DA
Fuel: VP Q16
Next step: VP M5 Methanol
